ATLAS COPCO AR-7.5-80H-208-230-3-P2 7.5 HP TWO STAGE PISTON AIR COMPRESSOR 80 GAL HORIZONTAL TANK 208-230V 3 PHASE
Atlas Copco set the standard for performance and reliability in the compressed air industry. The AR series of intermittent two-stage piston compressors are no exception with the capacity to meet the high demands of workshops and light industrial applications. The AR range brings out the best in quality efficiency and reliability in an affordable piston compressor.
Whether you choose a vertical or a horizontal model you get a compressor with exceptional reliability and minimum maintenance for a wealth of industrial applications. The Atlas Copco AR series of air compressors a hybrid cast iron and aluminum design that deliver up to 7.5 horsepower. While the 10 horsepower design a pump constructed entirely of cast iron.
Features- Highly efficient and easily accessible air filters for clean operation and longer lifetime
- Two stage slow speed compressor pump unit with finned cylinder
- Built in aftercooler for cooler running high efficiency and extended reliability
- Single and three phase motors to suit every supply voltage
- Standard magnetic starters on every model ensuring motor is adequately protected and starting is easy
- Start-stop pressure switch control
Specifications- Country of Origin: United States
- Horse Power: 7.5
- Motor Type: ODP
- Voltage: 208-230V
- Phase: 3
- CFM @ 100 PSI: 25.3
- Maximum PSI: 175
- Pump Material: Hybrid Cast Iron and Aluminum
- Pump Type: Two-Stage Piston Compressor
- Pump Drive: Belt Drive
- Oil Type: Oil Lubricated
- Oil System: Splash Lubricated
- Low Oil Shut-Off: Optional
- Oil Sight Glass: Yes
- Tank Size: 80 Gallon<
Price: 3084.00
