AutoLoc's Universal Power Window System allow you to convert your manual windows to power operated windows. The installation is easy because the motors connect directly to your existing window crank. Unlike other universal kits we offer heavy duty motors which meet or exceed factory standards.
AutoLoc's power window motors are worm driven for quick and dependable operation. A new and improved transmission and motor design assures a long life and plenty of torque. Because of their high-torque motors and custom mounting brackets AutoLoc's Universal Power Windows are great for older cars that have never had power windows. With each kit you will get 7 high quality Illuminated billet switches plug in wiring harnesses and switch mounting cases.
Each kit can also be upgraded to remote operation using any of AutoLoc's keyless entry units or window controllers.
Features
