BD DIESEL B70-1036750 E-PAS EMERGENCY ENGINE SHUTDOWN-DODGE
Features- Over speed shut down control utilizing built in Intake Air control valve
- Safely shuts your engine down if over speeding
- Can be installed in less than 15 hours
- Factory plug in connections and wiring harness
- Save 3 hours installation labor over mechanical systems
- Does not set ECM Trouble codes
- Automatically resets after shut down
- Only the switch needs a tool to install
- Easily removed for truck lease returns
Specifications- Weight: 1 lbs
- Dimensions: 8.8 x 6.6 x 2.3
Price: 1134.11
