CLORE AUTOMOTIVE SIBA327 20-2000CCA ELECTRONIC BATTERY AND SYSTEM TESTER WITH PRINTER
Features- Operating Range: 40 CCA 2000 CCA.
- Tests multiple battery types including Conventional Maintenance Free AGM Gel Cell Marine and Deep Cycle batteries.
- Temperature compensating for an accurate battery assessment in any temperature.
- Tests 12 Volt and 24 Volt Vehicle Starting and Charging Systems.
- Built-in printer documents battery and system test results.
- Large adjustable backlit display provides easy viewing in bright or low light environments.
- 10’ cable leads for extra-long reach.
- Reverse polarity and over-voltage protection.
- Packaged in a protective case for secure transport and storage.
- One year limited warranty.
- Dimension - 14.5 x 10 x 3.3 in.
Price: 504.15
