COBRA PRODUCTS 2487073 SPEEDWAY POWER AUGER DRAIN CLEANING MACHINE 0.625 X 100 FT. CABLE
Features- Speedway Power Auger Drain Cleaning Machine 0.625 x 100 ft. Cable
- 5/8 x 100' slotted end cable and 5 piece cutter set
- 3/4 HP heavy duty capacitor motor with forward-off-reverse switch and manual thermal overload protector switch
- Cleans 4 to 10 lines and is used for main drains sewer lines and root blockages
- Deluxe tilt-a-way power feed
- Dual handle wheels for easy loading and unloading
- Reinforced 19 molded cable drum
- Stair climbing skids
Specifications- Cable Diameter: 0.625 in.
- Color: Yellow Black
- Color Family: Yellow
- Horsepower: 1/2 HP
- Maximum Cable Length: 100 ft.
- Weight: 188 lbs
Price: 1794.49
