DEWALT DXCMLA1983054 30 GALLON CAST IRON - OIL LUBRICATED BELT DRIVE
Features- Cast iron twin cylinder oil lubricated pump
- Heavy duty induction motor for maximum performance and efficiency
- 30 gallon ASME vertical portable tank with pre-attached pneumatic tires for maximum portability
- Dual voltage motor is wired for standard 120 volt outlet and may also be converted for 240 volt application
- Equipped with quick-set regulator tank and working pressure gauges and on/off switch
- Drive - Belt Drive
- Horsepower - 1.9HP
- Power Supply - Gas
Price: 845.69
