DEWALT DXCMPA1982054 20 GALLON CAST IRON OIL LUBRICATED BELT DRIVE
Features- Cast iron twin cylinder oil lubricated pump
- Heavy duty induction motor for maximum performance and efficiency
- 155 PSI max pressure for optimum tool performance
- 20 gallon ASME portable tank with pre-attached pneumatic tires for maximum portability
- Dual voltage motor is wired for standard 120 volt outlet and may also be converted for 240 volt application
- Equipped with quick-set regulator tank and working pressure gauges and on/off switch
Price: 795.77
